Transpose two models
I have two models and both with multiple subTools. Now I want to pose them together, but how? Is there any way to put two ZTool models together and pose them seamlessly?
Thanks!
you could add one as a subtool of the other and use the transpose master plugin to pose them.
http://www.zbrushcentral.com/zbc/showthread.php?t=65409
I tried to append one as subtool, but it bring only one subtool element. And if I can append subtool as subtool, where I can handle “sub-subtool” elements?
Thanks
aside from merging them into 1 tool. you will probably have to save each sub tool out as its own tool and bring them in one at a time I am not sure I have never had to do this. You could take a look at the sub tool master plugin and see if there is anything there which may make the process easier.
actually just a thought when you append the tool does it bring across the selected subtool you could save yourself a lot of saving and importing if that is the case.
