Transpose Problem
Zbrush is crashing on me when I use Transpose master.
I combined all my subtools to one by hitting Tposemesh, then when I try to mask out an area with the transpose tools, and it just crashes. I noticed when I blur the mask, whether Im using the transpose tools or manually masking areas, thats when it immidiatly crashes.
Has anyone had this problem or know how I can fix this?
This is not an issue with TransPose Master. Which version of ZBrush are you using?
Does the crash occur if you manually click the Tool>Masking>BlurMask button rather than Ctrl+clicking on the model?
I am using R3, and yea the crash happened when I manually clicked the blur mask and Ctrl clicked.
But I noticed it was crashing cause of these 2 objects that I previously extracted in ZB and Uv’d in Max. The Uv’s were totally fine but those 2 objects were the cause of the masking error, I ended up redo-ing the object bases in Max, and now it works perfectly
I dont understand how an Extracted object from my original mesh can cause this problem…
