Transpose mode problem ..
if we have model with few polygons usualy in sculpt mode I click on the model with shift + ctrl and all the other polygons get hiden,and only those on wich i click are left visble,in the same way when i’m in transpose mode i start to make a pose for the model and i want to hide the other poligons i click on the model with shift + ctrl but nothing hapens ? in zbrush 3.5 it worked fine,is there a way to do this in zbrush 4.0 ? or how i can do this actualy?
Thanks
Hi PSTCHOART.
The Ctrl-Shift hide trick still works for me in 4.0
It hides the other polygroups on the model.
If you don’t have any polygroups assigned though, it does nothing.
AFAIK it’s always been that way.
G.
Hi grey32 ,
yes it’s work when you in DRAW mode but when you click on the transpose brush it’s doesn’t work :frowning:
My mistake. Sorry.
Yep. It looks broken. Works in 3.2 not in 4.0.
The select code is broken too. (http://www.zbrushcentral.com/showthread.php?t=92779)
But then if you’ve been through Pixologic updates before, you know that
a new release isn’t stable until at least the first point release. :cry:
G.
:frowning:
