Hey guys !
This problem seems to occur only on my mesh.
For some reason every time I use Tpose to SubT I get an error saying “No Matching Data” and I’ve no idea why.
I tried following these instructions:
- Before starting to use Transpose Master save out the model that you wish to pose as a ZTL by pressing the Tool>Save As button.
- Create a new ‘clean’ project, for example by loading the DefaultCube project through the Lightbox>Project tab.
- Load your ZTL into the new project through the Tool>Load Tool button.
- Use Transpose Master to pose your model.
And these:
- Load the pose model that you have saved. This should be a combined low res mesh created by Transpose Master.
- Export using the Tool>Export button and save as GoZ format (complete binary).
- Load the model you want to pose.
- Press the TPoseMesh button in the Transpose Master sub-palette. This will create a new combined mesh.
- With this new combined mesh selected, press Tool>Import and select the GoZ file you created at (2). The combined mesh should take on the pose. Note that if you get any warning messages that the mesh will be changed the meshes are too different and this will not work.
- Press the TPose>SubT button to transfer the pose.
Nothing seems to help.
Any help would be most appreciated.
Thanks !
I do not have the rights over the model and I am signed on a NDA.
