Transpose Master tpose remains
I feel like this is a newbee question, but here it goes: When I use Transpose Master, I end up with dozens of low rez Tpose models in my tool collection. Is there a quick workaround to deleting these? Is there a setting that doesn’t save the tpose model after using Transpose Master? My files double in size or more as a result of keeping these models. Many Thanks in advance.
If you have finished with Transpose Master then you can select the Tpose models and press Tool>SubTool>Delete to delete them. Note that if you want to continue with Transpose Master then this method might cause the plugin to not work as expected.
If you want to clear everything except your model then you can do this:
  1. With your model (with subtools) selected, press Tool>Copy Tool.
  2. Load a clean project through Lightbox, such as the DefaultSphere.
  3. Press Tool>Paste Tool.
With this method, all the Tpose models and Transpose Master data will be deleted, along with any other custom models except for the one you copy and paste. Saving the project (File>Save As) before you do this will ensure you have a back up.
Many Thanks, Marcus!
