Transpose master problems
Hi All,
Transpose master doesn’t transpose my main subtool, not even when I duplicate it.
All subtools have the same maximum subd level, all are on lvl 1.
  • I go to the main subtool (top) and select it
  • Go to transpose master select Zsphere rig and click Tpose mesh
  • Set up my Zsphere rig
  • Go to Rigging and click bind mesh
  • Set up my pose
  • Clic Tpose>SubT in transpose master
Transpose master gets to work but will come up with this error. After clicking OK, TM goes on and finishes with all subtools transposed except the main tool (and duplicates of that tool).
Am I doing something wrong, am I forgetting some vital step? What could be wrong here?
Cheers, Simon
Can you upload the ztool somewhere so I can take a look? I need to see the model to tell where the error is occurring.
Thanks,
Hi Marcus,
I just send you an PM with the download information.
I used this tool to setup a pose with transpose master in both ZB 4 and ZB 4R2,
it works in ZB 4 but not in ZB4R2.
Cheers, Simon
Any news on this problem?
Cheers, Simon
I am encountering this same issue in Z4r2b. Any ideas on what it could be???
I am having same issue with 4.3. Wont transform first subtool. What am I doing wrong?
W.
Zbrush and transpose master at times doesn’t play well with models who’s base level of subdivision has a high level of triangles. Where this threshold is I’m not sure. Some tris seem to work ok. A lot causes errors. There is an update for transpose master coming soon that improves this but high levels of triangles will still cause errors. I got mine to work by deleting the base subdivision level. (Because once you subdivide, triangles are converted to 4 sided polys).
Wayne
