Transpose Master problem
Hey, I have ZBrush 4 and I’ve downloaded Traspose Master Plugin, extracted it to ZStartup/Zplugs. When I relaunch program plugin is there but I can’t use it. I load Demo soldier and click TPose Mesh and it gives me this error:
ZScript Note: Interface item could not be found.
Tool:Export:XOffset
in…
(IGet, Tool:Export:XOffset)
The same thing happens with every other model/tool. Did anyone else had a similar problem or perhaps know the ways to fix this. Thanx.
which version of Z are you using?
transpose master should come pre-installed with every version 4+ I believe. My guess is you saved over something important.
You have the wrong version of Transpose Master installed. You need to select the correct tab in the Download Center so that you get the version for ZBrush 4.
Yup, I wasn’t looking at the tabs, ‘‘ZBrush 4R2’’ was selected. Downloaded the right one, works fine. Thank you very much :).
