Transpose Master Problem - Flipped Polys (Solved)
Hi. I’m sure this issue has probably been dealt with somewhere before, but I’ve had a search and can’t find anything similar.
When I use Transpose Master I’m getting flipped polys & a subtool inflating, as shown in the attached image. Can anyone help me out?
Mac OSX 10.6.8
ZBrush 4R2b
Edit: Problem solved, solution below.
OK, I just tried using Transpose Master with the Demo Soldier & all the polys on that guy got flipped too. I’m guessing the plugin hasn’t yet been fixed up for ZBr2b or something.
Can anyone else confirm this?
Weird solution, but after initializing ZBrush and that not working I thought I would try trashing the CustomUserInterface4R2.cfg file & return ZBrush to it’s factory fresh state. That did the trick. I guess my UI configuration somehow screwed things up in the update.
Just posting this in case anyone has a similar issue and does a forum search.
