Transpose Master Not Listed on Zplug palette
I may be missing something obvious, but I unzipped the contents of the Transpose Master zip file from the downloads center to Zstartup>>ZPlugs, but when I restarted Zbrush, I don’t see the option. I successfully unzipped/installed Subtool Master just before trying to add Transpose Master, so I think the folder hierarchy was preserved.
I’m using Zbrush 3.5 for PC, Vista 64 bit OS. I still have Zbrush 3.1 on the computer, and I tried installing Transposer Master on it, with the same result.
If you’ve got the same result in 3.1 then it seems your folder hierarchy must be wrong. The .ZSC file should be directly in the ZPlugs folder. Next to it should be the data folder.
And TransPose Master is included with 3.5R3. You should update to that version because earlier versions are no longer supported.
That’s how they were set up-- weird.
But thanks for reminding me to load 3.5R3! Just finished doing that, so now it’s a moot point.
