HI. I am trying Transpose Master and it seems the temporary low resolution merged mesh can be created all right (by pressing the TPoseMesh button), but when I complete any of the transposing operation and press the TPose>SubT button, only the main subtool of the original multi-subtool tool (in this case the naked body of the demosoldier tool) can be affected, with all other subtools(props) remaining in their original positions. A dialog box is shown saying “no matching data- subtool demosoldier_1 skipped”. So that’s wrong?
Thanks a lot!
Zbrush and transpose master at times doesn’t play well with models who’s base level of subdivision has a high level of triangles. Where this threshold is I’m not sure. Some tris seem to work ok. A lot causes errors. There is an update for transpose master coming soon that improves this but high levels of triangles will still cause errors. I got mine to work by deleting the base subdivision level. (Because once you subdivide, triangles are converted to 4 sided polys).
Wayne
