Hi folks
I’m having some trouble posing my first scuplt. So what I did was I started with the average male tool as my base, then I masked and extracted his clothing, and now I’d like to pose him. I’ve seen a bunch of videos where you start with the Transpose master zplugin, then you mask everything you don’t want to move, and then you can draw your transpose line and use move and rotate to reposition. The problem I’m having is after all the subtools are joined together, when I try to mask off an area, all it’s doing is selecting the subtools rather than letting me click and drag all the way across to mask it. Seems like the only way I found to make it work is to switch back to draw mode, paint on my mask the regular way, then switch back to move or rotate. It just seems like a bunch of extra steps for what looks so easy in the videos I watch.
So am I doing something wrong? Is there some other setting in transpose master that I missed to make it treat all of your subtools as 1 big tool as far as the masking and selecting goes?
that will probably work much better for me.
