Transpose Master - lowest subdivision level
hey all :slight_smile:
is it possible to use transpose master in a higher subd level than the lowest?
i could of course just delete the lower subd levels and reconstruct them but then the point order would change which i don’t want :stuck_out_tongue:
cheers chris
Hi Chris,
Not directly. Another workaround would be to load a copy of your ZTL, delete the lowest level for all subtools, then use TM to pose. After posing you’d need to export an OBJ for each subtool and import those into your originals at level 2. SubTool Master can speed up the export but not the import.
A lot of work if you’ve many subtools though. :frowning:
hey marcus :slight_smile:
yeah, that may take a while but at least theres a way.
maybe there will be some options in the next version of transpose master …
thanks, chris
I’ll bear it in mind…
Cheers,
oh … i didn’t have in mind you wrote it.
well, would definatately be great to have :slight_smile:
