Transpose Master is not working
I get this when I attempt to use transpose Master. How can I fix it?
Thanks,
Dave
Which version of ZBrush are you using and is it Mac or Windows?
Also, if you hold Alt and place the cursor over the Transpose Master>TPoseMesh button, you’ll see the TM version number at the bottom of the pop-up. What version is it?
Thanks,
I just upgraded to 4R4 and since then I have got the error. I am in windows. Transpose is version 4R3.04 14 april 2012.
Dave
Thanks, that’s useful. Do you get the error with a particular model or also (for example) with the DemoSoldier? If it is with a particular model then it would be useful if you could post it or send it to me for testing. I cannot reproduce the error.
Thanks,
Not sure if solved or if it helps, but I just fixed a same prob with older files of mine.
Make sure all subtools have different names! If You use GoZ for example or export/re-import meshes and they get the same names, the Transpose Master script fails.
Hope it helps.
Actually the more recent versions of TM correct duplicate names (by adding _copy1 etc.) so this should no longer be an issue.
