Hello I tried rigging with transpose master but this error appears: Script: TransposeMaster_4R7_01.txt ERROR: Tool:ZsphereIN: [Press, ToolZsphere]
What can I do ?
Thanks
Have you updated to ZBrush 4R7 P3? That’s an old version of Transpose Master. Also what OS are you using?
I was having this same problem, and I think I figured it out.
Apparently, you cannot rig using Transpose Master if you already have a Zphere object among your subtools.
You need to delete that Zphere subtool, and then the Transpose Master rig seems to work.
I guess it makes sense, since the transpose master rig creates a new Zphere to use as a base for the rig, it must find a conflict when you already have a Zphere subtool.
Hope it helps!
