Im using transpose master with Zbrush 3.5 and I’ve finished posing my model, but now when I convert back into subtools my Hi-res detail is gone. I still have the subdivision history but all of the detail is lumpy on the high res when it was crisp and clear before I posed. Is this a known issue or something I can fix?
I’ve not heard of this before. Can you post a screen grab? Transpose Master shouldn’t affect the hi res detail.
Pre Tpose:
OK thanks, that’s useful. It does only seem to be affecting the one subtool (similar detail on the others is OK). Which version of ZBrush are you using?
Its actually affecting 2 subtools, the torso and the tail (i didnt post the pic of the tail, these are the 2 of the 3 subtools that have hi res detail, The other subtool had its history deleted before I posed). Im using Zbrush 3.5 R3 with Windows 7
I’ve sent you a PM.
