Hi
I have installed and followed the directions for Transpose Master Plugin but everytime I use it it crashes Zbrush.
I am using only 4 Subtools and even with the Demo Soldier it crashs.
Anyone had same problem?
Hi
Which version of ZBrush are you running? (The version number is in the title bar.)
Which version of TransPose Master are you running? Where did you download it from?
What other plugins do you have installed?
Hi
I am running ZB 3.1.
I got the Transposemaster plugin from the Download center at Pixolgoic.
http://www.pixologic.com/zbrush/downloadcenter/zplugins/
I am using pretty much of all the plugins from download Center plus some others from ZBC.
I tried several time and it just keeps crashing. Just about to give up on it.
Thnx
Try the following:
