Hi.
Every time I dare to use Transpose master Zbrush instantly crashes when starting to mask. It happens all the time.
Windows 7 x64, 8gb ram.
Hi.
What, every model? This one model only? All masking? Topological masking only?
Try masking using the Lasso - this is generally better than using topological masking for Tranpose Master anyway.
Most models it happends with, but then I dont use it too often due to this problem which iv had since 3.5 had the projection master.
I have been using the lasso masking today, but in some cases topological masking is needed for like selecting lower lip or eye lids, fingers that are close together e.c.t. It only happends with Topological masking. I start to mask and instantly Zbrush crashes.
Thanks.
Thanks. Can you send/post a model that causes the crash so I can test?
