Transpose Master crashes everytime
I’m running ZBrush 3.2 on a Mac (OS 10.5.8) with Dual 2.8 ghz quad core and 8 gigs of ram. Every time I try to use transpose master it converts all of my subtools to their lowest level as a single subtool master. I then pose my character. However, when I click to convert back (T-Pose - Sub T), the computer hangs for a minute or two and then ZBrush crashes.
The only plug ins I have loaded are subtool master and transpose master. Are there any steps I’m missing, or has anyone else had this problem of constant crashes?
Is this a problem just with this one model or do you get the same behaviour with any model that you use Transpose Master with? Also, check that you’re using the latest version of TM (for ZBrush 3.2 not 3.12B).
