Transpose master crash
I seem to always have issues with this plugin making all my subtools and hard work useless… when trying to use it I keep either getting a crash that says I can get my tool from recovered files or I get this crash I’ve posted here…any help with this would be great thank you
Which version of ZBrush are you using? And do the problems always occur with a specific subtool?
Im using the newest version and no it just happens with this model…I can take some tools out and pose them separate but what a hassle!
There’s obviously something about one of the subtools that TM doesn’t like. If you can send me the file I’ll take a look. (I find WeTransfer is good for large files. PM me and I’ll give you my email address.)
Was this problem solved? Had the same once too and would like to know why. Thanx!
EDIT:
SOLVED
Make sure all subtools have different names! If You use GoZ for example or export/re-import meshes and they get the same names, the Transpose Master script fails.
Hope it helps.
