Transpose Master Crash
I just transposed a model with a bunch of subtools, saved the transposed tool, and when I clicked on Tpose>subtools Zbrush crashed as soon as it completed the operation. I opened up the single transposed tool again, but when I click on Tpose>subtools it asks to locate an OBJ file… is there any way to get this tansposed tool back into my orginal hi-res subtools? Or do I just have to start over from my non transposed model and hope this doesnt happen again…
You can save the Transpose Master combined mesh by pressing the TPoseMesh button while the combined mesh is selected. This saves as an OBJ file. If you saved it as a ZTL then do this:
  1. Load the combined mesh and export as an OBJ.
  2. Load the ZTL with subtools that you want to pose. Draw on the canvas and enter Edit mode.
  3. Press the TPose>SubT and then load the file saved at (1) from disk.
HTH,
Marcus, thank you so much! You just saved me hours of misery!
So i tried experimenting with this method and further divided some of my subtools in my regular posed model. I then pointed Zbrush to that same posed OBJ that I exported earlier after pressing Tpose>SubT and it seems that it starts working but then the program crashes on me. Do you think that this is because my computer is just to slow or would this generally not work?
