Transpose Master - Corrupted Project file?
Hi There,
Just looking for a possible explanation so maybe i could avoid having this happen again.
Been working in Transpose master for the last few hours, saving the project via the Save TM Project button iteratively.
Reached the end of the session after a couple of hours and hit the Tpose to SubT Button to check on how things where going.
Here is the result: ( note there are no error pop up messages upon conversion )
About 3 saves of the same project earlier the corruption is not present - Are there some clear no-no’s that I have missed that would cause this result ? The only subtool being corrupted is the body.
Windows 7 64Bit
12 GB Ram
Core I-7 960 3.2Ghz
Thanks for any help!
Hi there,
I have a similar problem - but my mesh doesn’t get destroyed like yours so much.
There are two errors:
  1. Some subtools won’t change their position after reposing
  2. Parts of the mesh which should be moved for posing - stays at their place - for example: moving hand - pologons of the fingertips stay on their position and rest of the hands stretches polygons to where you move them…
I tried both ways - Transpos Master with the Move/Rotate function and rigging with zspheres - same problem!
Anyone any clue?
