Transpose master and Z axis issue (solved)
I have this issue with transpose Master : I made my model in 3ds max, sculpted it, tweaked the proportions with TM and when I come back to my model, all my subtools have moved down along the Z axis…
Anyone knows how to avoid this issue?
thanx
Try this:
(1) Select your model after you’ve imported from Max and copy down the value in the Tool>Export>Z Offsett slider.
(2) Before transferring the changes from the TM posed mesh, enter the value from (1) in the Tool>Export>Z Offsett slider.
I’ve just tried and it worked perfectly! Thanks you very very much :wink:
