Has the ability to quickly mask using ctrl + drag while using the transpose tools been removed or changed? I can’t seem to get it to work on 3.5.
I’ve tried forum searching etc. but can’t seem to find any current info.
Thanx.
Thanx.
If you mean posing, you select the move, rotate or scale button and then control drag on a limb and make a mask based on topology. Then you you can pose it with the action line. Is that what you want to do?
There is a video in the ZClassroom in the essentials section that explains this.
Husse
Yes that is what I mean. But it doesn’t work for me on version 3.5. Though it still works correctly on version 3.1.
Ok thank you! I didn’t realise that there was some new videos hidden under the chapters tab there. Yes it’s function is changed slightly so it didn’t get it to work right away.
Again thanks for your input!
You’re most welcome.
Husse
