Hi there! I´m kind of new on zbrush, so, im working in an Amon model and when i pose it using the transpose plugin, after i clicked transfer tpose mesh, it deform my meshes, making some vetex go into diferent directions and ruinning my base mesh and detail, how can i solve this?
Which version of ZBrush are you using?
Im using Zbrush 4r3 for windows
You’ll probably need to be updated to 4.42 to make sure you can get the best support
isn´t there any other solution?
You can try redownloading the plugin at http://www.pixologic.com/zbrush/downloadcenter/zplugins/ to see if it’s newer than the version of Transpose Master that you currently have (R3 had an update as recent as April), but if that doesn’t work then you might be out of luck with R3. There’s a newer version of zbrush out (for free) with newer bug-fixing patches, and so I think there just gets to a point where outdated versions no longer receive the same level of support.
It fixed up with the update! Works perfectly now! Thank u =DDDD
