transparency
I just want to make objects transparent so i can see through the he object behind it. you know for references purposes. So do I need a plug in or is it in the program already. I have zbrush 4 for now so if you could just tell b/c im banging my head against the wall here
http://www.pixologic.com/docs/images/3/39/ZBrush_Cheat_Sheet.pdf
http://www.pixologic.com/docs/index.php/Render_Palette
http://www.pixologic.com/docs/index.php/Tool:Display_Properties_Subpalette
Activate edit opacity may be what you want.
Theres a nice thread on the forums too. Try the gel shader1. There are settings, be sure flatten layers is turned off in render properties.
gel shader thanks man for the assist
