Transparency refraction in ZBrush4R2
HI,
In ZBrush 4R2 the Refract and RFactor sliders in the BPR Transparency settings do not seem to be affecting transparent objects (unlike ZBrush4). Also, the Transparency slider in Material>Modifiers is not affecting the BPR render.
I enable BPR Transparent in the Display properties of the subtool and also enable Transparent on the Render>Render Properties. All the other sliders inside BPR Transparency are working, like NFactor or ByColor, just the refraction ones aren’t.
Can you please let me know if these are not working in ZBrush 4r2 or if I am doing something wrong?
Thank you,
Jose
I have the same problem… :cry:
for me nothing in for transparency seams to be working
im watching this thread, here is my thread I made before I saw this one.
http://www.zbrushcentral.com/showthread.php?162238-r2-transparency
anyone have any ideas? it worked fine before r2
Same here…
But I noticed that it works fine for subtools created in zbrush 4 and rendered in zbrush 4 r2…
Interesting… and annoying.
Nevermind… I found what was the catch…
But refraction still doesn’t work, though…
