transparency and reference image
Here is an easy way to model using transparency so you can see a
reference image in the background:
  1. Make 2 layers.
  2. In layer 2: Document/Import/“bkgrnd pic”.
  3. Set Render/Flatten off.
  4. Set Draw/“RGB Intensity” to under 70.
  5. Pick a material with a transparency setting. Then set
Material/Transparency to 100.
  1. Pick Tool/Zsphere. (Make sure draw size = 1.)
  2. Now in layer 1 you can draw out your Zspheres and model.
Attached is my recorded Zscript showing it in action…
Thanks so much for the awesome guide. It helped me a lot and now i can easily create one.
Thanks a lot.
Regards.
Brian
