I’m new to zbrush so I apologise if this is a stupid question. The tutorial I’m doing requests transp enabled so as to aid in distinguishing between subtools. It says nothing about having to turn this function on? did I miss something? Any help, much appreciated.
Just toggle the transparency button on the right side off and on. It allows you to see through your subtools to get a better sense of placement. I’ll usually turn transparency on and then use the arrow keys to select up and down subtools to quickly see through various parts of the entire model. Helps you get a better sense of your piece. Once your done just turn if off and your model will be totally solid.
Cheers lad much appreciated. The button itself was disabled, but I restarted and its okay now. Just wondering if something would cause the button to be disabled?
