Transform > Local and the camera
I was wondering if someone can explain what is happening when you press the “transform > local” button. It changes the camera perspective of whatever tool is currently on the canvas and I was just curious why and what exactly is going on behind the scenes.
Thanks :slight_smile:
Normally, symmetry applies to the main tool. It’s for use with subtools.
About 3/4 of the way down>> http://www.pixologic.com/docs/index.php/Transform_Palette#Symmetry_Controls
Thanks Doug, I know what the button itself does. I was just curious why a button that “Determines how resize and rotate functions are performed while editing 3D tools…” appears to also make your camera’s perspective focal length also change when you press it.
nm.
