I use Lightwave 11.6 on a Mac and 4R6. Transfer model using GoZ beautifully. After I work on mesh in ZBrush and add eyes to mesh I then transfer back to Lightwave using GoZ. But the eyes don’t transfer. I must be leaving out a step or two? Suggestions? Thanks. Larry
In the Tool palette there are two buttons to the right of the GoZ button - ‘All’ will transfer all subtools, and ‘Visible’ will transfer the visible subtools. You need to press one of those.
Thank you! I will give this a try!
