Thanks for the reply.
I will give it a try and let you know.
meanwhile I found something that seems to work, but the 2 meshes MUST be exactly the same (topology wise and so on).
Usually, I save a file when my sculpt is final and unposed.
Then I do another file for the posed version. And it’s better to have this pose version on a layer.
Basically these steps can save you when you forgot to pose your model on a layer, just like me.
Here are the steps and I just tested on a small piece, it seems to work:
A-For the neutral mesh in HD
1-Lower subd level to 1 and delete higher
2-Export as .obj
B-For the posed mesh in HD
1-Create a new layer and name it “Pose Layer”
2-Set subd level to level 1
3-Import the obj of step A
Now you have a “Pose Layer” to play with.
When it’s on “0” it is posed. When it’s on “1” it’s neutral.
C-Modifications
1-Create a new layer and name it “Sculpt Layer”
2- Set layer “Pose” to “1” so it’s neutral
3- Sculpt on the “Sculpt layer” to make the changes
4- When it’s done, set layer “Pose” on “0” to see your HD model posed and with your changes you just made.
