Transepose
HOw can I copy a transpose manually done pivot in order to not again and again position it. So that can a tool have many pivots?
You could duplicate the subtool, the pivot can be moved if and when you wish to rotate it. If you don’t need to see it, hide it.
I want to have many pivots for one subtool for making a pose for example
Maybe you should investigate building a ZSphere armature? http://docs.pixologic.com/user-guide/3d-modeling/modeling-basics/creating-meshes/zspheres/basic-humanoid/
I tried and the results are not as good as with transpose
First you create the armature, next an adaptive skin (your model). Later the armature you made in step one can be used to pose the adaptive skin made in step 2. See rigging. HTH
thank’s
