Tranpose master not selecting subtools?
I’m trying to pose a mesh with multiple subtools, but I am unable to select mulptiple stools with the topology masking. I watched a video explainign how to do it using ctrl and shift, but all that does it hide parts of my mesh.
Can anyone help?
Topology masking won’t work with the TPose combined mesh because the subtools, although all one mesh, are still separate geometry. The Lasso is the best way to mask across subtools.
I basically just need to scale a model’s size, but also can’t scale multiple subtools at once…
I think it’s impossible.
Now i’m basically going to export low detail versions, scale it all up in 3dsmax, and import back into ZBrush, and REDO all the detail work. :cry:
Transpose Master should work fine for scaling:
  1. Press the TPoseMesh button to combine all your subtools into a single low res mesh.
  2. Use Tool>Deformation>Size to scale the combined mesh.
  3. Press TPose>SubT to transfer the scaling to all your subtools.
There is a video on youtube of a guy being able to select multiple subtools after masking certain areas of the mesh. but i cant get it to work?
