Tracers from model
I keep having image tracers from my models when moving or scaling. Is there a fix on the way?
It messes up my export for the shots on a render. Please help.
if its what i think then they are canvas artifacts. use CTRL+N to clear the canvas. also this happens if you use the move/scale/rotate buttons in the interface or popup, it usually does not happen if you use the ALT based hotkeys for those functions.
Thank you,
Your a good friend Spaceboy, and probably one of the only ones that follows my posts. Thank you very much for being there as a reliable friend.
