Hello all
A while ago I built a dinosaur model- Call it model A. Science decided the proportions of model A were all wrong ( based on new fossil material) so I changed took the same mesh and built model B. They both have the same Polycount, just very different proportions.
Model B has far more detail and is a better sculpt. However, the science has changed AGAIN and the proportions of model A turned out to be more accurate.
I recall that a long time ago I saved a Tposh mesh as an obj and then could import it onto another more detailed model ( again, made from the same base mesh) using the Tpose to Subt button. It worked amazing.
Now, several Zbrush versions later that trick doesn’t work, it says that no matching data is found. What happened?
Any other ideas of how the get detail from Model B onto Model A? I tried the importing trick and its not working for me. Perhaps the models are just too different now?
Thanks
