Topology...using the move tool
I posted this earlier but the post didn’t appear…appologies if its the second time you’re reading this.
I’m doing some work with the topology tool and I am having problems with the move tool. When I create vertices the sit nicely on the surface of the reference geometry…great!
The problem I have is that when I go to move the verts to create better poly spacing, the verts move away from the reference surface (either above or below it) and they just aren’t following the contours… I would assume that the topology tool would snap the verts to the reference mesh’s surface, whatever tool you are using.
Am I missing something or do I have to manually go in and try to find the correct position for the verts? Surely not??
Cheers,
Simon
that’s normal. delete vertex and redo it.
