Topology problem
Hello
When I select topo in the Topology menu, i can not see the lines… on the mesh… (I am doing topology on a face)
I know that to press Edit Topology button can help… but not for me…
Can somebody help me?
(I am om Mac, ZBrush version 3.12)
:confused:
Are you following the typical workflow for topology? ie. Select ZSphere, append ZTool you want to retopologize, Rigging --> select mesh, Topology --> Edit topology
yes…
When i do normal topology (edit topology) all seems to work…
but when i use Select Topo… i dont get to see:
  1. the lines
  2. the lowbodymesh witout the face
I just see the high res mesh… (without lines)
I hope its something i do wrong… but cant find it…
:o
Ok now, in order to reload a previously saved Retopology session and work on it, you need to go into Edit Topology.
Select Topology only is for viewing and and editing the Topolgy on an existing mesh. In order to do that, you still need to draw a ZSphere on the canvas, go to Topology, (make sure the mesh has less than 15.000 Polys) click on select Topo, choose a mesh and click on edit Topology. Now you can change the Topology of that mesh.
Hope that helps.
Thanks…
I have to many polys i guess…
Must do it again…
:smiley:
Well no, just go into edit topology and you should be ok.
When i go down in points/polys, it works… (select a version early in the development)
Is it then the points/polys who is the problem?
Another way to do it…
:confused:
