Topology Lines partially invisible
Hi there!
I am fairly new to zBrush and today looked into the topology feature a bit.
I wanted to edit the existing topology of a model, but I had slight problems with editing and viewing the existing topology (lines).
As you see in this screenshot, there is topology lied out all over, however there is a fair amount of topology lines that are invisible on the screen.
By hovering with the mouse and keeping alt down in places, where there obviously should be a topology line between two topology points, but which does not show up, the cursor actually switches to the delete-line cursor, so I suppose there really are those lines. (Also the preview does not have any holes.)
However, also my moving the points around I could not get those lines to show :frowning:
Also, funnily enough, the hidden topology lines are not even symmetrical.
Anyone ideas what this is and how to fix it? - Greatly appreciated.
k.
Try toggling the Edit Topology button.
Also try pressing Tool>Masking>Clear
Hey,
thanks for the tip.
Unfortunately those things did not help with the problem.
I still have a topology from my old base mesh that has unsymmetrical holes in the display (not in the Tool:Adaptive Skin:Preview though - but what good is it if I can’t edit it, or only partially)
Here another image to better illustrate the problem:
So, just to make sure, here the things I do to get there:
  • Open highpoly tool, go to lowest subDiv (smart resym gives me 100% btw) and safe it.
  • Switch to ZSphere
  • Tool:Rigging:Select Mesh and pick my highpoly tool there
  • Tool:Topology:Seleect Topo and pick my lowpoly tool there
    (- Toggling Tool:Topology:Edit Topology and Tool:Masking:Clear, just to make sure)
Any help really appreciated, because like this I can’t edit it, nor do I really want to completely lay it out new again.
Cheers,
k.
