I ran into a weird issue today with zbrush, all my subtool are invisible, they are still here because I can see their preview in the subtool menu and they appear if the transparent mode is active but if not, there is nothing even if I do a “ctrl n” and I recreate them. I do not know how I did that or if it is a bug of Zbrush ?
I tried to reload the tool with a new project,zremesher the subtools, duplicate the subtool, … but the bug is still here
I hope it can be easily repaired, thanks if you know the solution
It is not a solution but for now, the only way I find is to export the tool as obj and reimport in the project and split it and then redo the subdivision level by zremesh
Thanks
Hello @123EE_M
Can you document your issue with images please? Please post a completely un-cropped image of your entire interface with the subtool palette open. If you are not comfortable doing this on the community forums, then you can go to Pixologic Support, and start a conversation there.
Thank you!
