tool disappeared !
I ran into exactly the same problem as this one here >> Help! Noob locked out of sculpting but, I know exactly when it’s happened.while I was in edit mode, I accidentally clicked on edit and locked myself out of sculpting,normally when this happens I just hit ctrl+N and load the same tool and continue sculpting but this time around something weird happened,that tool just disappeared ! I mean it’s still there but you can’t see or edit it,did I miss something? or is this a software issue? I wasn’t sculpting anything important so this time no harm done but,it it is software issue how should I avoid it happening in the feature?
Are you using Zbrush 4R6 P2? System Specs?
yes I am,
windows 7 sp1(X64)
8GB RAM
sapphire HD 7770 DDR5 1 GB graphic card
but normally ctrl+N trick works and when it happened there wasn’t any complex mesh just a sphere with bunch of snap tubes.
Just to try. Go to Tool->Display Properties->Flip
hummm, I can’t reproduce the problem whenever it happens again I’ll try that out thanks :slight_smile: hey did you checked my other questiontrouble with appending and ctrl+Z
