hello guys,
In those days I am working on an hard surface model.
I am experimenting that, even if the subtools are not so much (almost 15 pieces), the weight of the project is very hig: 1.142.000 KB, so the first question is: Is this weight too much for a model composed by a low number of sub tools?
Consiedr that, at that point, I have just started. I can’t imagine the final amount of KB that will compose the mesh at the end!!!
The way I work is the follow:
I am extracting sub tools masking them from a concept mesh (a dynamesh about 300.000 polys) and then polishing every piece with various techniques: clip curve, Hpolish and so on.
If I need more detail, I subdivide the mesh. One, two or three time. Not more. So I have sub tools that start from 50.000 to 60.000 polys and others that are more thick, about 200.000, 600.000 polys.
Generally I use poly polygroups meshes, If necessary I add GroupLoops or Edgeloops. Other times I auto group the polygroups. I noticed that if I transform them in dynamesh, then they result in more heavy object in therms of KB weight.
I described the way I work just to help u to figure what I am doing. Maybe there is somethig wrong in my methods.
Finally, I think the weight of my project is too much.
Don’t sure if I am right or not.
Some one could help me, please?
Thanks for the attention and best regards
matteo
