Try to translate a 2d concept into acceptable 3d artwork. I hope you all like it.
(inspired by TONTON REVOLVER artwork)
That is some heat right there. Would you mind explaining how you did the water? I’m rather new to texture/rendering.
thank you, the water is a simple plane with BOSS (Bifrost Ocean Simulation System), the material is an “aistandardsurface” in Arnold. in the transmission section you can play with the manipulators and reach your goal for a good water effect, but you can always use Arnold preset for material as a base and then tweak it as you want.
