Tidying the palettes
Often I have to load many objects to do some small changes, so it’s import - edit - export, one after the other.
As a result, the Tool palette is getting longer all the time because every object is represented by a thumbnail and I have to scroll a lot to access the tools I need. Same with the subtools; when the list gets longer ZB tends to forget the objects I’ve loaded a minute ago, but the very first ones are still there… :confused:
Is there a way to tidy up the palettes, to clear out those objects I don’t need anymore? (except from closing and re-starting the program, I mean)
in the tool panel near the top there is a small “r” button, that will reset the thumbnails, this doesn’t clean out the main picker though. To do that, preferences>init zbrush…that is basically a restart without the load time. Make sure you save before you init Zbrush though.
Also, using Subtool Master will help with the importing and exporting process…1 click to get all of your objs in your scene. or out of your scene for that matter
Thank you! :slight_smile:
