Apologies is these have already been covered but I was not able to find the answers in search. Here they go-
Often times when I create a tool (especially if I use shadow box) then try to use radial symmetry the symmetry is off. I can move the tool manually but its quite difficult to line it up just right. Is there a way to auto line you tools in the center to work with radial symmetry?
How to heck to I make a perfect circle with the clipping or masking tool. You dont hold shift like in photoshop you hold…I dont know! Help!
Often times when I create something and clip it the polygon grid seem very uneven. If I try to use a texture box it only really works on some surfaces and corners. Same goes for the shafts of cylinders. Isnt there a way to more evenly distribute the poly grid (I have no Idea if that hows you refer to it. Noob!).
Noob alert! Thanks for the help!
Oh boy. Put this in the wrong place. Can I delete this or have it moved to general discussion please?
