thicker parts
Hi
ok I have a question, Ive been having trouble with a 3d print job. the part was made in zbrush… the issue seems to be thickness. so a couple of questions
how do I increase the thickness of apart internally in order to make a solid model instead of a hollow one?
and when creating an extraction how can I get the thickness to be internal rather than external? at the moment you set the thickness, it creates the extraction using the mask as the mid point so you get half in and half out, I want all in and little out from the mask position.
Steve
