The texture always reset on 1024 x 1024, how to create texture larger than that ?
hello,. I have a silly question,. how to create a texture polypaint with resolution larger than 1024 ?.
I’ve already made 2048 x 2048 or 4096 x 4096 new texture, hit the Txr>Col button, and start painting, but everytime I hit the Col>Txr button, the output texture reset to 1024 x 1024. i’ve tried many times with diferent resolution in new texture,. but the result is always the same, the output is always 1K. why it happen ?
  • Polypaint your ztool.
  • In the texture pallet, set the texture size you want, then hit the NEW button. This will drop a new texture at the desired size into the active texture slot. Initially, it will be filled with your foreground color in your color pallet; the default is white.
  • Your ZTool will also temporarily be filled with white, but don’t worry about it. Just go to the Texture section of the Tool pallet and hit COL>TXR. That will take your polypaint color information and stamp it onto the texture that’s currently sitting in the active texture slot. Now for a warm and fuzzy feeling, take your mouse cursor and hoover it over the open texture slot to see the info flyout - it will tell you that the texture is at the size you set earlier.
  • Export as PSD.
db
Wow it works now, so that’s because of my wrong workflow :stuck_out_tongue: hehehe,. thank’s for your help dustin. I really apreciate that :slight_smile:
