The Return Of The Fell Beast
HI TO ALL ITS G8 2 B BACK AFTER QUITE SOME TIME :smiley: .SO M POSTING MY LATEST WORK COMPLETED WHICH WAS IN ITS W.I.P STAGE WHEN IT WAS LAST POSTED HERE.WANTED TO GIVE IT A CINEMATIC/DRAMATIC LOOK.
THE DRAGON WAS MADE USING ZSPHERES & IMPORTED INTO MAYA WHERE THE RIDER AS WELL AS THE ACCESSORIES WERE MODELLED:)
BESIDES ZBRUSH AND MAYA PHOTOSHOP WAS USED IN POST PROCESS.
HOPE U GUYS LIKE IT.HERE GOES…
KINDLY POST UR COMMENTS & SUGGESTIONS :smiley: HAVE A G8 DAY-EMILLIANO
nice work. i just about started playing with a fell beast today but started to play with transpose.
THANX LOKI 22 FOR UR COMMENT.:slight_smile:
Hi. I like the scale and pose very much and the anatomy feels pretty solid.
The skin texture details are nice. If I might suggest something it would be that the color could be improved by varying the temperature and value for different parts of the beast. For example, the under-wing might be lighter and less saturated than the top of the wings.
HI jbuck THNX SO MUCH 4 UR COMMENTS WILL KEEP IN MIND ABOUT THE WING AREA.:slight_smile:
<double post>
Always nice to read posts with capslock…just curious : if lowpoly is 448802 triangles, what is highpoly ?
Great Dragon You Have There…nice Fleshtones.
The firelight mask is abit too obvious on the dragon though, try to lit it n 3d if possible.
HI SOYSEITAN THANX 4 UR COMMENTS -HIGH POLY MODEL CONSISTED OF 3.26M POLYS.WILL KEEP IN MIND UR SUGGESTIONS.THANX:D
