Hi. I have one problem in ZBrush 4R7 P3. When I press Ctrl-click on the canvas then resets the mask and not inverted. The same thing happens if I press Ctrl to select an area of the canvas. I know that it should not be. Maybe I can somehow restore inverting pressing Ctrl click on the canvas?
Check the setting for Preferences>Interface>Click>Click Distance. The default is 10 but you may need to adjust this. (If you change it, remember to store the configuration by pressing Shift+Ctrl+i)
If that doesn’t work then you can press the Tool>Masking>Inverse button to invert a mask, and you can assign a hotkey to that button.
marcus_civis: - Thank you the first way to help and now everything works. I remember that I wanted to remove Click menu on the right mouse button so changed the settings in the Click menu. Immediately after that the inversion of the mask was gone. It turns out these functions are somehow interrelated.
