the painter of 22th century
Curious painting
Left Clic…clic…clic… to Zoom in
Right Clic…clic…clic… to Zoom out
left and right keyboard arrow to turn.
Hi Fouad
I don’t very well understand where is the “painting” mode ?
It’s just a visualisation in the 3D space or there is a part of painting object ?
There are some brushes in the files but how used it ?
They said object from Lightwave (.obj) but have you try with some object obj from Zbrush ?
It’s the same format ?
Pilou
Ps they said press P or Space for the next object but I have seen nothing more?
Pss ALL the arrow keys for ALL rotations !!!
arff Pilou, this is just a real time mini 3d engine witch render as a “painting” matiere.
about import I tried some modele low meshs but it crash.
and “P” ou can watch the object selected in wire frame mode.
Not really utility with that tool as that, just a demonstration of 3d coding.
and they put the source code if you want to do for us a new painter 3d… :))
about psssss… yes… I was not going to make you complete instructions…
otherwise, are you tried the free screen recorder that posted in other thread?
try it… it will be very very usefull and it have many functions very nice.
No But I shall try just a test with Zbrush Because I haven’t the recording aload as demo user :rooleyes:
But i am a little afraid about the multi
task !
Pilou
don’t be affraid… :))
you must just choose a good codec… only
Hi Fouad
Ok I try it with Winds3D and Zbrush :slight_smile:
All seem works :slight_smile:
What Codec ?
I just record in Avi , is any other possibilities ?
I have made my try at 100% of the screen.
Result is quasi perfect excep a little lost of definition ! maybe 4% (not of the size) of the definition, the clearness !
En 2 mots l’image n’est pas identique à l’original, mais c’est très lisible :slight_smile:
And what is arrived when the Short cut F8 (stop the record) is used by the program that you record ? Conflict or Not ?
And it’s seems that the prog use is some slow down ?
But you right it’s amazing :slight_smile:
Of course the file resultant is some heavy, but now we have DvD :smiley:
Thx again for this sort of true gem prog :slight_smile:
Pilou
last question : there is not the same in the native XP Windows system ?
codec = codeur decodeur.
avi is only a contener, you must specify the engine video compression, as microsoft video1(bad) or cinepak(bad) or divX4/5 (better) or Xvid etc…
this codec will improve or detroy the quality of your video record, and final file size.
ex: with microsoft video 1 you can have for few minutes a 500 Mo file size and bad quality…
the same time with divX( for exemple) can do 10 Mo and good quality.
clic on compression button and choose a codec installed in your computer… If you don’t have divx… download it (google codec divx).
about function key F7/F8 I never use them with any software that I have. so no conflict, but if you have this case… just change them…
But where I define this codec in the “Sreen recorder” ?
Or you want to say that Imust modify the avi file resultant ?
Forget the Above I have found : it’s the button compression :rolleyes:
So new trying :slight_smile:
Pilou
Hum hum
I have this codec but the “Screen Recorder” say when I choose it in the list :“Selected compression can not be used ; choose another” ?
What is yours ?
The format DivX is a “legal” format ?
Pilou qui n’y connait pas grand chose dans ce secteur :slight_smile:
New try
full Screen 1280*1024, Quality of compression 100%, mode watch it enable (nothing is recorded when nothing change on the screen)
Codec MPeg, wings3D session with a simple object mirroring and extruding and smoothing
3 minutes = 20 megas
Is a normal size ?
And no doubt the multitask slow down the prog recording in reasonable manner!
Hi Fouad;
This looks interesting. I’m gonna download it
and give it a try when I get some free time.
Thanks for bringin’ it up!
:b2:
If it comes down to altering any foto or fotorealistic picture, transferring it into something more “natural”:
http://www.gertrud.com.ar/
I think you will like this!!
Hi Ze
You can make exactly the same with Zbrush than gertrud !!! :smiley:
Just import your Photo on plan3d and use any alpha with different intensity of Z :slight_smile:
Not many people has make that here because re copy a photo is some infament but sure you can!!!
For the fist programme it’s more evoluate because you can make that on some volume in 3D space and rotate it !
But Zbrush again can make that :slight_smile:
Zbrush is a pure true gem :smiley:
Pilou
you’r welcome Matvara :slight_smile:
Zerebrush thx for this link :wink:
Pilou… of course Divx is legal format… what is illegal format for you…?
codecs can be installed on your system… and any video application can use them.
so if your list of codec is short… find for exemple … “sld pack codec” and install it.
well mpg is good format… but Xvid or Divx … or even MP4 from Microsoft better then.
3 mn musr do approximatively less than 1 Mo… but … if you want an advice, dont capture entire screen… as a draw bigger screen … bigger file size.
so … push “Select source button” and choose “a region” a frame will appear resize and press enter … that 's better.
try many codec … to find the better.
and don’t affraid… nothing illegal… ahahahah :)))
ps : for sound… that same, you have the sound codec as… Mpeg Layer 3 (MP3) gsm, dsp, wma pcm, adpcm etc…
