The Mushroom Elf
Hi all!
Here is a new WIP character…hope you like it :slight_smile: I’m not sure how to paint him…again…and waiting for you C&C :slight_smile:
wish I had thought of it, first! If you want advice to texture him, I would just take him into Projection Master and go for it. Use a material with good cavity shading, since I see him as weathered, instead of bright, plastic-like colors.
Anyway, looking forward to seeing your results.
Thank you Slosh! Can you suggest such material? Because I’m new to this :o and I want to make him more realistic then plastik, you’re right :wink: vbmenu_register(“postmenu_189983”, true);
A little update…still more to go…
:slight_smile:
i like the last one
Thank you, it’s not finished yet, I still have plans for him :slight_smile:
Here is a start of “Planning a scene” :slight_smile: But I will work more on characters too.
p.s. Background and blurry grass are temporary here :slight_smile:
A little progress… Can you tell me how to give scene more deep? I plan to put some more mushrooms for the BG…
Render > Depth cue
I’m tryin’ it now… :slight_smile:
